MF 35 questions
Jeef
11-25-2007 07:07:52
I am looking at a MF 35 Deluxe. It is a gas engine and it has a loader. it runs strong all gears work without issue. I an the loader for the short time I had it running yesterday it was pretty slow but I am atributing that to the 32 deg weather. The bad is the rear rims are badly rusted one almost gone and the rear tires are rough.
My questions.
Before I buy this tractor is there anythingI need to watch out for in this model?
What is the diffrence between a 35 and a 35 deluxe?
Are parts readily avalble for this model?
How much will it cost me to replace the two rear tires and rims?
Anything else I need to know?
I have operated tractors all my life but I never had to do more than check the oil. I don't mind working on it, I just don't know much about them.
Dean
11-25-2007 16:17:01
 Re: MF 35 questions in reply to Jeef, 11-25-2007 07:07:52
Jeff:
If it is a deluxe it will have power adjust rims. These are available but cost around $300 each or a bit more. Add another $200 each for tires and around $35-$30 each for tubes and you are over $1000 for tires, tubes and rims.
If a deluxe, it will also have live PTO and a dual clutch. Check to be sure that both work well as this too is expensive to replace.
Does the loader run from the tractor hydraulics of does it have a separate front mounted pump? If it runs from the tractor hydraulics it will be slow due to the limited capacity of the tractor pump.
Check the condition of the front axle pivot pin and spindle bushings. Loaders are hard on the front end.
Most parts are readily available for 35s.
Dean
Jeef
11-25-2007 18:26:07
 Re: MF 35 questions in reply to Dean, 11-25-2007 16:17:01
Dean I forgot to answer the rest.
The loader is run off of the tractor hydraulics.
I thought about a front mounted pump but didn't know what would be nvolved in doing that.
It had detent style valves on it now and I do not care for them as they lock when you are letting them down. I guess that is a convience.
The tractor is ugly, but seems in decent reapir other than the rims and tires.
They are asking 1300 for it. I just don't want to put a mint into is getting it up to snuff.
Dean
11-26-2007 03:37:34
 Re: MF 35 questions in reply to Jeef, 11-25-2007 18:26:07
Jeff:
The loader will be slow if operated from the tractor pump.
The 35 is a nice tractor and should be well worth the asking price if any good at all. Decent ones bring $2500 without loaders.
If you have the time and inclination to give it some TLC, it sounds like a pretty good deal.
Dean
Jeef
11-25-2007 16:54:25
Is there a way to switch to the standard wheels if it has the power adjust? I don't see me ever needing to move the wheels in and out.
Dean
11-26-2007 03:34:25
 Re: MF 35 questions in reply to Jeef, 11-25-2007 16:54:25
Yes, you can use the 6 loop rims that cost around $120 each but you will need to change to the matching wheel centers.
Dean
Jeef
11-26-2007 17:06:44
 Re: MF 35 questions in reply to Dean, 11-26-2007 03:34:25
Well so much for that, I was going to see it again with the money in my pocket. The fella called wanting to know if I was going to buy it or not. I Said I wanted to look at it again before I could comit and he told me to forget it and hung up.... So much for my reasonably priced tractor.
One thing I found out tday weather true or not. I was told by the massey dealer that the centers on the spin outs are the same as the ones on the 6 hole. I cannot confirm this but that was what I was told. Jeff
Jeef
11-26-2007 17:06:40
Dean
11-27-2007 03:03:34
 Re: MF 35 questions in reply to Jeef, 11-26-2007 17:06:40
Jeff:
Your MF dealer is absolutely wrong. I have both types. The wheel centers are not even similar.
Dean
Jeef
11-27-2007 05:51:28
 Re: MF 35 questions in reply to Dean, 11-27-2007 03:03:34
Ok, That was just what they told me.
