MF water temperature?
Terrie
11-23-2000 08:09:12
What would be a normal water temperature on an MF 65 tractor.
Thank you
Terrie
11-23-2000 20:12:26
 Re: MF water temperature? in reply to Terrie, 11-23-2000 08:09:12
Thank you guys.
Terrie
Alberta Mike
11-23-2000 17:46:42
I guess it would depend on the thermostat that is in the tractor, and also whether or not it is working or not. If it's stuck closed, then your temperature is going to be hot, but if it's stuck open then it's going to run cold. If it's working correctly, then it will run at the rating of the thermostat. Why not pull it out and put a new one in (your choice as to temperature and this would depend on whether you use it only in the summer, or both summer and winter)? Check with your dealer as to what they recommend. Anywhere from 160 - 190 degrees Farenheit would be OK.
Pat
11-23-2000 19:13:27
 Re: Re: MF water temperature? in reply to Alberta Mike, 11-23-2000 17:46:42
Factors such as rated plug temperature, coolant quality, how well the coolant circulates through the rad (is it partially plugged?), how well the water pump is working, etc. can also affect your operating temperature. I have found my MF 65 operates consistently in the low end of the 160-190 range, both on the hottest summer (90 F) and coldest winter (-40 F) days in Saskatchewan (I am sure Mike can relate).
