pulling tranny on a MF 250
jhanlon1
11-21-2007 07:46:52
I have got the tractor ready to pull the tranny, ie the front end and engine are out. Wiring harness, hyd lines, brake and clutch pedals removed. Is there a trick to getting the tranny out other than supporting it with a lift and removing the bolts?
casey
DavidP, South Wales
11-21-2007 11:58:13
 Re: pulling tranny on a MF 250 in reply to jhanlon1, 11-21-2007 07:46:52
Yes, when you think that you are ready check everything again. Make sure the back end is well supported.
DavisP, South Wales
GaryF
11-25-2007 17:24:31
 Re: pulling tranny on a MF 250 in reply to DavidP, South Wales, 11-21-2007 11:58:13
be sure to knock a wood wedge in on each side between the front axle and the block casting to prevent it from turning on the axle pivot pin...GaryF
