MASSEY FERGUSON 135 STEERING PROBLEM
Larry McNurlin
11-22-2000 16:15:49
I recently purchased a 1967 MF 135 which has a problem with the power steering. It steers ok to the left but doesn't power steer to the right. Manual is ok. The previous owner had the pump and rack replaced and no help. Anybody have any bright ideas where to look for the problem before I pull it apart?
David
11-23-2000 20:06:29
 Re: MASSEY FERGUSON 135 STEERING PROBLEM in reply to Larry McNurlin, 11-22-2000 16:15:49
I have a 175 with the same problem. If your tractor is set up simular to mine, the cylinder has a control valve that governs it. There is a control arm with a nut on the end of it. Depending on where you position the nut determines how well the tractor steers left or right. If the nut is centered properly, the tractor will steer as it should. If too far one way or the other, you will have steering for one side only. If the control arm is badly worn, it is almost impossible to adjust. I put a new arm on mine, adjusted it, and the tractor steers fine now, David.
