MF power steering leak
wcmark
11-13-2007 07:25:58
I have a MF 65 diesel that has a leak at the drive gear. I contacted the MF dealer anfd they told me that they can't get the parts. Can anyone help. Thank you
DavidP, South Wales
11-13-2007 09:12:07
 Re: MF power steering leak in reply to wcmark, 11-13-2007 07:25:58
Hi,
Generally the seals go hard or split and loose their ability to seal. If you can remove the old one without too much damage you should find a number on it that a seal supplier can use to match it up.. Once the pumps start leaking here you probably only have a 50/50 chance of the repair working. Taking into account the age of the tractor and probable hours worked there is sure to be wear in the bushings and spindle.
Cheers
DavidP, South Wales
oldhousehugger25
11-25-2007 17:36:19
 Re: MF power steering leak in reply to DavidP, South Wales, 11-13-2007 09:12:07
I am rebuilding a Massey Ferguson 35 and one of the to fix items is the power steering pump. YT Tractor has this info as to model numbers of the pump.
"Replaces 193208M91, 518369M92, 527904M91. (40149S) (Part No: 773126M92)"
It is the pancake can type which bolts to the back of the timing gear housing. They list a new aftermarket as 260 USD but when I cleaned it up all I could really see wrong with it was the old Bendix internal canister filter had slipped off to the side and wasn't filtering anything.
2 questions.
Will a pump with high case wear still give some power assist even though the pressure is low/ Can anyone point me in the direction of finding a replacement filter element. I assume the reman units have a filter so somebody has to be making them. The Bendix filter part number is 046916. The size is 2 1/16 dia. and 1 1/2 inches tall with a 23/32 whole in one end and corrugated paper element. Any help would be a step in the right direction.
