Massey Harris
Leigh
11-13-2007 02:36:42
Am trying to find out what model and year my Massey Harris is as I need a water pump for it. The only identification I can find is on the rhs of transmission housing and it is 3223A 8 447. Can anyone out there please help
Leigh
11-26-2007 01:46:15
 Re: Massey Harris in reply to Leigh, 11-13-2007 02:36:42
third party image
Have posted an image of tractor, am still trying to identify it. not much in the way of MH tractors in Tasmania
Cheers
MH Poor
11-14-2007 08:19:38
On the top of the transmission on the clutch side under the seat are some numbers and letters stamped. You may have to scrape years of gunk to see them. They are the same numbers that were on the tag. Post them, and someone can look them up.
Crazy Horse
11-13-2007 16:42:54
Well, let's start with some questions:
1. Massey Harris or Massey Ferguson?
2. Flathead engine or overhead valve?
3. Hinged sidepanels or no hinged panels?
4. 6 cylinder or 4 cylinder?
5. Cast iron front tub or channel iron tub?
Answering these 5 questions will narrow it down quite a bit.
Leigh
11-14-2007 00:47:48
 Re: Massey Harris in reply to Crazy Horse, 11-13-2007 16:42:54
answer to your questions are
1. Massey Harris
2. Flathead engine, side valve
3. no hinged side panels
4. 4 cylinder
as the tractor is used to put a boat in water down at the beach house and is not avail to view straight away can not say about the last question.
Thanks for your help.
I reside in Australia and quite hard to find parts if I dont know the model
Crazy Horse
11-14-2007 06:49:28
 Re: Massey Harris in reply to Leigh, 11-14-2007 00:47:48
Well then, that narrows it down a bit. Sounds like a MH model 30 (evolved from the 101/102 Juniors) or maybe a Mustang or Colt (evolved from the 81/82/20/22 series). We are assuming that the "no sidepanels" means they were never there, not that they are simply missing (which is often the case). The 30 had a cast iron tub while the others had a channel iron steel front frame. The serial number is hand stamped into the top surface of the tranny differential housing. More specifically, to the left side between the shifting platform and the cover over the differential gears. It is there, probably filled with paint and other stuff, use a wire brush and you'll see it, the numbers are big but might not be stamped too deep. Once you find it, post it here and you'll ID it no problem.
phillip d
11-13-2007 16:14:32
Any chance you can post a picture of your tractor?It would be very helpful in identifying it for you.pd
Leigh
11-14-2007 00:49:27
 Re: Massey Harris in reply to phillip d, 11-13-2007 16:14:32
Will post pic as soon as I get one.
Cheers
