1927 MASSEY WALLIS 20-30 WATER PUMP
MIKE FARMER
11-10-2007 13:04:51
This message is a reply to an archived post by BILL BC on January 14, 2004 at 23:28:02.
The original subject was "1927 MASSEY WALLIS 2030 WATER PUMP".
Hi.I have just been reading the archives and have found a piece about Wallis 20/30 water pumps. This is causing me a bit of heart ache (to say the least)So anyone ablke to respond to the following Please I am at the start point doing a wallis 20/30 rebuild. At least I shall be when I get all the parts in the same county. Like you I am looking for information. I cant even find out how to pack it. Like you said the manual doesn't give this info( at least mine doesn't.HELP MTF
Mike Farmer
11-13-2007 11:31:36
 Re: 1927 MASSEY WALLIS 20-30 WATER PUMP in reply to MIKE FARMER, 11-10-2007 13:04:51
Thanks for the help coming my way. No it does not have a 'big nut'. The impeller is on the Magneto drive shaft with a large spring pushing against the front face of the impeller. The shaft appears to run in two bushes with possibly a washer in between. I have not stripped it as I do not yet have sufficient knowledge to proceed safely. As you will all be aware mistakes on these old tractors are difficut to rectify often simply because there are so few bits available. A further question:- In view of the proximity of all the engine oil, is the clutch considered to be a wet clutch. It would certainely appear to be
Thanks again MTF
Kevin Meier
11-12-2007 19:28:30
Can you send me any pictures? I have been building water pumps and torque amplifiers for 15 years and once in a while ya forget the applications and casting numbers but maybe a pictuer will trigger something.
Massey Harris Steve
11-11-2007 07:03:42
You can try the Massey collector's web page. There are quite a few Wallis collectors.
masseycollectors.com
AllanC
11-10-2007 18:51:57
Well My Wallis experience is on the older ones, but... Does it have a packing nut - a big nut with a space behind it. If so you wind " steam cylinder packing" in there to fill it up then grease with water pump grease. You can still buy water pump grease but they used to use a stiffer heavier grease than you get now. Packing comes on a roll and you just cut off what you need.
