MF40B Clutch???'s
GaryF
11-05-2007 15:54:19
Looking a 40B, it has a manual shuttle trans/PTO & 3-point hitch it looks a little ruff but it is straight. There is wear on bucket and cab is missing glass looks like the diff lock is non functional (arm resting on the floor.)
I have not heard it run yet (tomorrow).
The clutch pedal goes smoothly down with no change in the effort required to push it to the floor making me think it is a single clutch. Was MF still using single clutch transmissions this late? Did they have an independent PTO(hyd engagement) on some industrials? is there a SN or other number on the casting that would indicate if it was single or dual clutch. I have been told that on some dual clutch tractorsthat did not use the PTO the clutch was adjusted so that the 2nd stage did not work. I do not know how to tell this. Thank you for any help...Gary
Joe T
11-06-2007 21:26:40
 Re: MF40B Clutch???'s in reply to GaryF, 11-05-2007 15:54:19
Its easy to tell if it has hydraulic PTO,right next to PTO engagment lever there is a small test plug, or ,with engine shut off spin the PTO and engage the lever,if it feels like your putting a trans shifter in gear,then its a dual stage clutch. Joe
MF40Industrial
11-05-2007 18:50:47
My MF40 Industrial has a live PTO (dual clutch type). It definitely has the feel when you press half way down, it gets a lot stiffer. Mine is a 1970 model probably quite a bit older than yours.
GaryF
11-07-2007 10:29:37
 Re: MF40B Clutch???'s in reply to MF40Industrial, 11-05-2007 18:50:47
Well I bought it anyway(weakness)looks like it has a split torque clutch and an independent PTO with a bad brake or the clutch packs are messed up bigtime! Thanks for responces...Gary
