help with F-40
Les Royer
11-03-2007 01:23:09
Can someone help me with a carb for this tractor? It was in my garage when it caught fire and I can't afford to buy a $250 carb just to see if it will still run. It has the z-134 gas engine. Les
Jeff Z.
11-03-2007 10:10:15
 Re: help with F-40 in reply to Les Royer, 11-03-2007 01:23:09
It should fit. The replacement for and Allis Chalmers CA and a MF 40 are the same. The CA Carburetor will fit the Allis Chalmers B. I think the CA carburetor might be jetted different .
The Allis Chalmers B carburetor on you MF40 might just be lean but it should run your engine enough for a test.
Jeff Z.
11-03-2007 07:09:13
I have an old Zenith off an Allis Chalmers B you can have if it will work for you.
Les Royer
11-03-2007 09:34:11
 Re: help with F-40 in reply to Jeff Z., 11-03-2007 07:09:13
I have no idea if the carb you have will fit and/or work on my massey. I know very little about this tractor. I'm smart enough to change it, but I don't know what kind of carb it is. Les
