Water in Air OilBath Filter (FE35)
Craig in New Ze
11-17-2000 01:36:22
Hi Folks,
Help again please. Some time ago I noticed seepage from the oil bath air filter where the lower bowl joins the mid section - a detailed look showed that the whole bowl had filled up with water!. I realised the top intake half round portion of the filter had a hole in the middle (where the formed spring seats). I put a plastic bag over the top intake portion of the filter (only when not in use of course) to stop the water (rain) from running straight in and down into the lower bowl. However today (2 months later) I see the seepage again and discover the bowl is again full of water!.The plastic bag is stopping any entry from the top so any idea's where it could be coming from?. Thanks as always.
Rex, ex kiwi
11-18-2000 22:52:25
 Re: Water in Air OilBath Filter (FE35) in reply to Craig in New Zealand, 11-17-2000 01:36:22
If you are leaving it out in the rain, water can enter through other places like the join where the bowl fits. Once water makes a track, it will keep flowing and fill up anything, I've even seen it flow past a gear lever in to the gear box.
And from what I remember, it sure rains a lot in New Zealand
Go All Blacks,
Rex
