Massey 22 questions
MT in Walford
11-01-2007 16:06:00
I have a Massey Harris 22 Standard.
I have a couple of questions.
1. The belt pulley is not installed. It has a plate over where it goes. Does it still need to have gear oil in the belt pulley transmission box?
2. I bought a oil filter from a Massey Harris dealer. It came with a rubber grommet on each end of the filter. I had to take one of the grommets out on the lower end to get the filter down far enough. It still has a leather washer on below the filter. Is it correct?
1950 Massey22
11-01-2007 19:01:26
 Re: Massey 22 questions in reply to MT in Walford, 11-01-2007 16:06:00
I still run some gear oil, about 1/2 to 2/3's of recommneded amount if belt pulley is present although the belt pulley drive shaft is not there. Oil is cheap compared to something going wrong.
As far as teh oil filter, I just use the rubber ring on top of the filter.
MT in Walford
11-01-2007 19:26:58
 Re: Massey 22 questions in reply to 1950 Massey22, 11-01-2007 19:01:26
Thanks so much. That helps me. Is your 22 a standard or a row crop?
Pastor Mike in Walford Iowa
