F-162 carb kits?
johnlobb
11-01-2007 16:01:09
I have a Lincoln SA200 Pipeliner welding machine with a Continental F-162 flathead 4 cyl engine. It is around a "51-"53 vintage. it has a Marvel-Schebler carb on it and I understand some Massey-Harris tractors of that vintage used the same motor. Is this true? If so, where could I buy a carb kit for it? Thanks, John L...
Steve Forrest
11-05-2007 13:46:16
 Re: F-162 carb kits? in reply to johnlobb, 11-01-2007 16:01:09
Just google 'TSX308' (or whatever your model is) and you will find a few suppliers.
44 massey
11-01-2007 16:14:14
MH30 and some 101 jrs used the f162. They used a marvel schebler carb however the throttle shafts were different but used the same basic kit (kit without throttle shaft). The model number of the MH30 carb was a TSX307 for the fuel burners and TSX308 for the gas burner, the 101 jr used model number TSX155!
old
11-01-2007 16:13:14
Find the carb numbers, most of the time there on the back side so you have to pull the carb to get them. The use that and call a good auto parts store and they should be able to get you one. Other nice thing is M-S only made 3 or 4 different size carbs and so because of that there is only 3 or 4 carb kits made for them. Just an example but a carb kit that fits a 9N/8N is also the same kit for an Oliver 60 and a good number of others so you stand a good chance that a kit for a 8N will be the same since the engines are close to the same size so the carb will be also
