Seal #'s for MH 81 82 or 20 rear axles ???
Crazy Horse
11-01-2007 13:39:55
I know I can go with measurements but I'm wondering if anyone has replaced the seals for the MH series 81/82/20 tractors. That would be the inner (oil) seal between the axle and the differential and also the outer (grease) seal in the removeable bearing end plate that holds the axle and outer bearing in place. Any seal numbers (and manufacturer) would be appreciated. The numbers might have to be crossed over but that should be no problem.
ChuckBergstrom
11-01-2007 17:31:26
 Re: Seal #'s for MH 81 82 or 20 rear axles ??? in reply to Crazy Horse, 11-01-2007 13:39:55
The Inner seal is MH p/n 17308a and a National #
50085. The corresponding felt is p/n 17308a. The
outer seal is MH p/n 17222a and National 50315.
The felt for that one is 17216a. There is a co.
in Chilton,Wi that has both felts and the outer
seal under MH part no. if nothing else works. This
company buys o'stocks and discontinued from the
dealers and the companies. They will only sell to
an implement dealer so order from your favorite.
The company is called The Parts Depot. Chuck
Crazy Horse
11-02-2007 04:15:58
 Re: Seal #'s for MH 81 82 or 20 rear axles ??? in reply to ChuckBergstrom, 11-01-2007 17:31:26
I appreciate your response Chuck. Thanks for your help. I will get the seals locally and then see if someone here can order those felts for me.
