Help with MH50 steering parts
Dennis Moore
10-30-2007 17:22:02
I have a MH50, manual steering, wide ft end that I lost steering on. I removed the cover on the steering gearbox only to find that the bearing on the lever stud has exploded. Where can i find this bearing? looks like a double tapered roller. Maybe someone has a bearing # that NAPA can cross over? Thanks for the help. Dennis
Don_G
10-31-2007 04:26:46
 Re: Help with MH50 steering parts in reply to Dennis Moore, 10-30-2007 17:22:02
I had to replace mine and couldn"t find the stud and bearing by itself anywhere including salvage yards all over the States and Canada. There were two types of studs used. The newer type is available from Sparex but the older type with the double tapered bearing is NLA. I finally bought a complete used steering box from a salvage yard. I have since found that Wengers in Myerstown PA has a used steering lever with stud for sale. Search their site for part # 1751862M91 or call them at 800.451.5240. Their site has a picture that you can check to see if it matches yours.
Incidentaly, I also found most of my ball bearings in the bottom of the steering box as the shaft had worn enough to let them fall out of the races. This is another reason I went with the complete box.
Don
