Multi Power
finsrn
10-30-2007 10:10:56
I appreciate everyone's responses so far regarding my prospective purchase of a 165. However, I'm still wondering what happens when the multi power fails. By failing I'm assuming that this means it will not engage in high any longer. Besides the fact that there will be no engine braking (or pull starting), will the tractor still function as a normal non multi power tractor with a manually engaged high-low transmission? Or, will the whole transmission lock up, spring annoying leaks and/or render the tractor useless?
JBMac
10-31-2007 11:24:41
 Re: Multi Power in reply to finsrn, 10-30-2007 10:10:56
Some folks say that the tractor needs to be put in MultiPower high occasionally to keep the plates wet. Mines been stuck in low for a long time, years, with no ill effect, but I suppose it's a valid theory.
Bob N.Y.
10-30-2007 17:21:17
The tractor will still function as a straight 6 speed, but there will not be any engine braking capability.
finsrn
10-30-2007 17:45:38
 Re: Multi Power in reply to Bob N.Y., 10-30-2007 17:21:17
Thanks Bob. I guess that makes good brakes absolutely nessary.
504-2
10-30-2007 19:03:43
 Re: Multi Power in reply to finsrn, 10-30-2007 17:45:38
No matter what, do not pull start a M-P tractor,it wont start and the clutch pack doesn`t like it at all.
