MF245 broken front bolster(axle pin)
Pappy(Ky)
11-15-2000 19:32:50
Saw a first today, my uncle's MF245 front bolster broke where the front axle pivot attaches to it, near the crankshaft. I KNOW MF's are tough but didn't expect it to break where it did, right through the middle of the rear grease fitting. Is this a "common" failure for this type of axle? Our other Masseys(245 and 255) have nary a scratch in this area. Never had a loader on it either.
bbott
11-16-2000 16:40:26
 Re: MF245 broken front bolster(axle pin) in reply to Pappy(Ky), 11-15-2000 19:32:50
My 245 has an expertly repaired break in the front axle at just about EXACTLY the same spot you describe.
However, It did have a front end loader for a good part of it's life.
I'd always blamed abuse of the front end loader for the breakage.. but from what you say, there may be more of a weak spot there than I thought.
At any rate, the repair has held 'good' for many years now.
bb
Update
11-17-2000 19:26:23
 Re: Re: MF245 broken front bolster(axle pin) in reply to bbott, 11-16-2000 16:40:26
Went back and checked the damage. Appears the front pivot point on the bolster has also broken in at least a couple of places. It's getting ugly fast, may be time for a new bolster or a 'lot' of welding. bb, it's good to hear that a good welding job has held that long, thanks for the input.
