Help ID this Massey Harris tractor.
Matt06br
10-29-2007 18:35:50
I recently looked at a Massey Harris tractor that was forsale on an old farmstead had it left me and another Massey nut puzzeled as to which model it was. First I forgot my camera so here is the description. The tractor is a standard and not a row crop. The rims were round spokes not cuttoffs, It looked like a pacemaker or a 25. The air cleaner was cast iron. It had two access covers on the block on the carb side of the engine(just like McCormick 10-20). It had a five gallon or so round tank behind the gas tank. The carb is really differnt i havent seen one like it before becasue there is a 2" opening that comes strait out the side away from the engine. The seriel number plate says model PA. The seriel number is 108230. Let me know what it could be I think it is a 25 or a pacemaker but there are differneces from the pictures of these models.
ACEd
10-29-2007 20:22:15
 Re: Help ID this Massey Harris tractor. in reply to Matt06br, 10-29-2007 18:35:50
1936 Massey Harris Pacemaker Model PA with Kingston carb - extra tank s/b 1 5/8 gallon - either aux fuel if tractor fuel it would start on gas from small tank - or if gas, it could be a Vaporizer water tank - MH patented for fuel savings - sounds like a water injection system but I don"t really know other than what I read in Keith Oltrogge"s book.
Briar Creek Stables
10-29-2007 20:32:51
 Re: Help ID this Massey Harris tractor. in reply to ACEd, 10-29-2007 20:22:15
Massey-Harris Pacemaker General tractor information: Manufacturer: Massey-Harris Model: Pacemaker Type: Farm/Agricultural tractor Years produced: 1936 - 1939 Total built: 26,557 Factory: Racine, Wisconsin, USA Tractor power: Drawbar (rated): 16 hp [11.9 kW] Drawbar (max): 30.6 hp [22.8 kW] Belt: 27 hp [20.1 kW] Engine: Manufacturer: Massey-Harris Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke: 3.875x5.25 inches [98 x 133 mm] Displacement: 247.7 ci [4.1 L] Rated RPMs: 1200
1400 (Twin Power option) Cooling: liquid Torque: Firing order: Transmission: Type: gear Forward: 4 Reverse: 1 Mechanical: Fuel: 18 gal [68 L] Aux. fuel: 1.6 gal [6 L] Coolant: 20 qts [18.9 L] Power Take-off (PTO): Tires: Ag front: 28x5 steel Ag rear: 44x10 steel Ag front: 6.00x16 Ag rear: 11.25x24 Dimensions: Weight: 3,700 lbs [1678 kg] Wheelbase: 78 inches [198 cm] Length: 122 inches [309 cm] Width: Height: 53 inches [134 cm] Ground clearance: Electrical: Ground: Nebraska Tractor Test 266: Test Date: August 1936 Engine: gasoline Belt (max): 29.1 hp [21.7 kW] Drawbar (max): 19.8 hp [14.8 kW] Nebraska Tractor Test 294: Test Date: October 1937 Engine: gasoline Twin Power Belt (max): 42.1 hp [31.4 kW] Drawbar (max): 30.6 hp [22.8 kW] Serial Numbers: Location: On rear-left portion of tractor frame. Comments: The Massey-Harris Pacemaker replaced the Wallis 12/20 in Massey's line. The Twin Power feature increased engine rpms to provide additional horsepower for belt work. The Pacemaker was a standard (wide) front tractor, while the Challenger was the row-crop version.
Briar Creek Stables
10-29-2007 20:29:00
Massey-Harris Pacemaker General tractor information: Manufacturer: Massey-Harris Model: Pacemaker Type: Farm/Agricultural tractor Years produced: 1936 - 1939 Total built: 26,557 Factory: Racine, Wisconsin, USA Original price: Tractor power: Drawbar (rated): 16 hp [11.9 kW] Drawbar (max): 30.6 hp [22.8 kW] Belt: 27 hp [20.1 kW] Engine: Manufacturer: Massey-Harris Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke: 3.875x5.25 inches [98 x 133 mm] Displacement: 247.7 ci [4.1 L] Compression: Rated RPMs: 1200
1400 (Twin Power option) Cooling: liquid Torque: Firing order: Transmission: Type: gear Forward: 4 Reverse: 1 Mechanical: Chassis: Steering: Brakes: Capacity: Fuel: 18 gal [68 L] Aux. fuel: 1.6 gal [6 L] Coolant: 20 qts [18.9 L] Power Take-off (PTO): Tires: Ag front: 28x5 steel Ag rear: 44x10 steel Ag front: 6.00x16 Ag rear: 11.25x24 Dimensions: Weight: 3,700 lbs [1678 kg] Wheelbase: 78 inches [198 cm] Length: 122 inches [309 cm] Width: Height: 53 inches [134 cm] Ground clearance: Electrical: Ground: Nebraska Tractor Test 266: Test Date: August 1936 Engine: gasoline Belt (max): 29.1 hp [21.7 kW] Drawbar (max): 19.8 hp [14.8 kW] Nebraska Tractor Test 294: Test Date: October 1937 Engine: gasoline Twin Power Belt (max): 42.1 hp [31.4 kW] Drawbar (max): 30.6 hp [22.8 kW] Serial Numbers: Location: On rear-left portion of tractor frame. Comments: The Massey-Harris Pacemaker replaced the Wallis 12/20 in Massey's line. The Twin Power feature increased engine rpms to provide additional horsepower for belt work. The Pacemaker was a standard (wide) front tractor, while the Challenger was the row-crop version.
