Need a new battery for MF 135
Matthew Rice
10-27-2007 17:01:32
Hi, the battery on my MF 135 (diesel) has been weak for a while, and now it has finally given up. The battery that is on it now was an old one the man had laying around when I bought it, and I think it has over 900 cold cranking amps, but it has always sounded weak so I don"t know it was just the battery itself or I need more cca. How many cold cranking amps should I look for when I replace it? Thanks, Matt
JBMac
10-29-2007 05:35:51
 Re: Need a new battery for MF 135 in reply to Matthew Rice, 10-27-2007 17:01:32
Don"t overlook your wiring. A big starter wire and grounding straps with good, clean connections makes a big difference.
Gerald J.
10-27-2007 19:42:36
My owner's manual says you want a 95 AH 12 volt battery. Since they don't specifically rate batteries that way these days, you need 228 reserve minutes at 25 amps load.
Or go measure the battery box. Get the highest rated battery (cranking amps, CCA, reserve minutes) that will fit in the box. The more overrated the battery is the longer it will last.
Likely at least someting in a #4 family, not a typical car or truck battery.
Gerald J.
BigMarv1085
10-27-2007 18:22:31
Matthew, I put a exide 750 cold cranking amps in my 135. The same battery was used in my 1085 for a while and it started fine. In my 135 it turns over but not as fast as the 1085. I think I might need to rebuild the starter.
