MF 300 crawler help needed
w williamas
10-25-2007 15:02:23
Crawler has a 248au diesel engine that suddenly started smooking(and using a quart of oil per hour). I pulled the head and found a sleeve that had slipped down about 1/2 inch but it appeared that it had been running that way for quite some time, and no evidence of oil pumping on that cylinder. Any way, I now need to pull the oilpan, but the crossmember is in the way of getting to the pan bolts and dropping the pan. I've got a couple of ideas foe working this problem out, but would like to hear from someone with experience. thanks, mw
w williams
10-25-2007 17:19:52
 Re: MF 300 crawler help needed in reply to w williamas, 10-25-2007 15:02:23
Marlowe, thanks for the reply. The two bottom oil-pan to transmission bolts are impossible to remove because of the crossmember/front axle. Can the crossmember bolts be removed and the front of the crawler be jacked up to gain access to those bolts to remove the engine?? mw
Marlowe
10-25-2007 17:29:44
 Re: MF 300 crawler help needed in reply to w williams, 10-25-2007 17:19:52
I'm sorry but it's been a long time that i worked on one i do know i never removed the gross bar but i think i pulled the converter and engine in one just don't remember
Marlowe
10-25-2007 15:14:55
when i had my 300s i found it easier to just pull the engine then trying to do things with engine in not a lot of room witch you have found out
