Three point linkage arms dropping
Huw from West W
10-16-2007 12:04:24
Why do the linkage arms seem to drop on most MF tractors when you turn the engine off . I have a MF 265 and it has always done this since i have owned the tracor , otherwise the hydraulic system works brilliantly .
DavidP, South Wales
10-16-2007 13:34:06
 Re: Three point linkage arms dropping in reply to Huw from West Wales, 10-16-2007 12:04:24
Hello Huw,
The standard Massey Ferguson answer to your question is "why do you want them to stay up?"
I agree it would be helpful if they could be locked up but from a safety angle all implements should be lowered to the ground if the tractor is to be left for any period of time. Leakages can occur from a number of locations. Obviously on a new tractor any leakages should be absolutely minimal. The most likely places on worn tractors are from the lift cover cylinder and the stack pipe O rings. If you have an isolating valve, shutting it with an implement lifted will give an indication of the condition of the piston and cylinder by the time it takes to drop.
Regards
DavidP, South Wales
