Oil type for MF135 Diesel
jay50
10-15-2007 15:03:50
I inherited a 1972 MF135 Diesel and would like to know what type/weight/brand of oil is recommended. I live in NC and normal high temps are 90s and lows around 32F.
Thanks for any help
Finn Md
10-18-2007 13:21:46
 Re: Oil type for MF135 Diesel in reply to jay50, 10-15-2007 15:03:50
15-40 works good in my MF135D and MF165D. I now use Shell Rotella 15-40 and it seems to keep a little better oil pressure while doing harder work when hot outside than other oils I've used. Otherwise, just get a good name brand 15-40 oil and change every 100 hours, and before winter storage, and you're good to go.
Rod in Smiths Falls, ON
10-15-2007 15:31:09
Pretty well everybody uses 15-40 for diesels in engines like these nowadays.
MF Poor
10-15-2007 16:06:56
 Re: Oil type for MF135 Diesel in reply to Rod in Smiths Falls, ON, 10-15-2007 15:31:09
What he said!
I've been using Pennzoil 15/40 in my MF150 diesel (Perkins AD3-152. same engine as 135) for years. Nothing but praises. Starts easy without heater @ 5 degrees. (coldest I ever tried) Runs steady oil pressure after 8 hours of bush hogging in 104 degree heat. 1971 model, never overhauled, uses less than a pint of oil in 100 hours (between changes) Couldn't ask for much more.
