Rear wheel lubrication
Frank Ryan
11-11-2000 12:53:54
Can anyone with knowledge of 1964 Massey Ferguson model 65 tell me where check/fill hole is on rear axel. I can find drain plug on lower forward side of axel and breather plug on top of casting, but I can not locate fill plug. I have already drained and need to refill. Thanks for any imput you may have.
Jack in NB
11-13-2000 06:03:47
 Re: rear wheel lubrication in reply to Frank Ryan, 11-11-2000 12:53:54
Hello Frank -
Sounds like you are referring to the final drives - near the outer end of the axles.
Ours has oil level/filler plugs - about 1 1/16" heads - on the front of the axle casting, outboard of the fender mounting flats, about 1/4 of the way up from the bottom.
The parts book shows smaller drain plugs on the very bottom, but ours does not have these.
WVMARK
11-11-2000 19:20:44
The rear axle and transmission are common gear boxes and although they have seperate drain plugs, they use a common fill plug. The one on top of the transmission beside the gear-shift fills both the transmission and the rear end. Don't forget to check the oil level in the final drives.
Good Luck!
