Engine overrhaul or not?
MT in Walford
10-11-2007 07:03:06
I bought a Massey 22 std. The engine is tired. It leaks oil and when it is run oil comes out the vent pipe. How do you tell when it is time for an overhaul?
It doesn"t smoke in just running it. Where do you get overhaul kits?
Did this engine come with sleeves?
Thanks
Mike
ChuckBergstrom
10-11-2007 16:25:14
 Re: Engine overrhaul or not? in reply to MT in Walford, 10-11-2007 07:03:06
Mike, This Continental 140 engine did not come
out with sleeves. Chuck
MT in Walford
10-11-2007 16:42:32
 Re: Engine overrhaul or not? in reply to ChuckBergstrom, 10-11-2007 16:25:14
Ok Thank you Chuck.
How do you tell if a block needs bored or just cylinders honed?
Mike
1950 Massey 22
10-11-2007 15:45:47
All 22's were gas, no diesel. Sounds like it is time for an overhaul. Kits are easy to find as Massey used Continental engines. Done 2 of them and had no problem finding parts. Losts of forklifts, welder engines were made by Continenetal. Montes in Chicago is aslo agood source, phone number 312-225-2660
MT in Walford
10-11-2007 16:20:20
 Re: Engine overrhaul or not? in reply to 1950 Massey 22, 10-11-2007 15:45:47
Do you have a Massey 22? Do you know if the Continental engine has sleeves or it will need to be bored out?
Thanks
Mike
K.W. in Tx
10-11-2007 14:52:04
I got a massey 203 that started blowin oil, it needed rings and sleeves so I just rebuilt the whole thing while I had it apart. Not familiar with mf22 tho. Is it gas or diesel out of curiousity?
MT in Walford
10-11-2007 16:18:51
 Re: Engine overrhaul or not? in reply to K.W. in Tx, 10-11-2007 14:52:04
It is gas, a Continental F140 engine I think.
Mike
