175 tune up specs
J. Brock
10-09-2007 15:57:35
Where can a guy find all the tune up specs for a 1973 175 gas MF? And what in the heck are them extensions on the spark plugs?
Steve NW WI
10-12-2007 02:28:33
 Re: 175 tune up specs in reply to J. Brock, 10-09-2007 15:57:35
Not sure which motor you have, but here's what my I&T manual gives for specs
C=Continental engine P=Perkins engine
Static timing C 6 btdc P 10 btdc
High Idle timing c 26 btdc p 32 btdc
point gap .022 (both engines)
plug gap .025 (both)
low idle c 475 p 750
high idle c 2225 p 2250
compression 145-160 psi (both)
valve tappet gap (hot) intake c .016 p .012 exhaust c .018 p .012
also gives valve angles if needed, let me know. I'm not on here a lot, but email works
hope this helps,
Steve
JBMac
10-10-2007 10:37:00
Get a manual as soon as you can (genuine MF). They are available on ebay and from the dealer. I've never worked on a gas 175, but I have come across extensions on sparkplugs that were supposed to keep them from fouling. If this is the case, you may need more than a tune-up.
J. Brock
10-10-2007 13:50:00
 Re: 175 tune up specs in reply to JBMac, 10-10-2007 10:37:00
I did a quick comp. test and all cylinders tested out at around 150 and it doesnt smoke that I know of,so I figured the motor is not to bad,but that kind of worries me if them are there to keep plugs from fouling. I have absolutely zero past history of the tractor.
