Question about lift hydraulic pump MF40 Industrial
Merlin Phillips
10-08-2007 21:23:59
Having pulsating lift arms, I pulled the side plates off to check out the pump / insides. I see a steady strong stream coming off of the pump at the rear just above the filter area. Is this where the pressure relief should be. If so, it is not holding the pressure up to what it should be I think. Does anyone have any advice on what I should do next?
Thank you all very much.
Merlin
DavidP, South Wales
10-09-2007 01:10:31
 Re: Question about lift hydraulic pump MF40 Industrial in reply to Merlin Phillips, 10-08-2007 21:23:59
Hi Merlin,
Pulsing or the arms reaching a set position then falling slightly, raising again and falling etc is normally due to a significant leak in the system. The arms reach the selected height, oil is lost, the arms drop and then the linkage tells the pump to lift the linkage back to the original position. If you watch the lever at the rear of the pump you will probably see it moving as it goes through the cycle.
Leakage can be from any number of places but the common ones are the piston under the hydraulic cover, damaged O rings on the stack pipe and worn poppet valves in the pump. Usually a full removal and inspection is required.
Cheers
DavidP, South Wales
