44 rear main seal
Eric Platz
10-08-2007 18:14:09
My 44 specials rear main engine seal has slowly gone from a slow drip to a steady stream. Where do I order a seal and pan gasket through? should I put an oil pump in right away? what is the easiest way to do this? Do I have to pull the engine or can I get away with taking the clutch housing out? any help appreciated!
Fred Wolfe
10-09-2007 11:04:11
 Re: 44 rear main seal in reply to Eric Platz, 10-08-2007 18:14:09
I have rear main seal and oil pan gasket.
ChuckBergstrom
10-09-2007 05:21:55
Eric, I see no need to put in an oil pump unless
there is a problem with it. You need to lift the
engine-turn it sideways and it will sit nice on
the frame. IMPORTANT-keep track of the shims on
the front of the engine mt.and keep it the same
or you could break the drive shaft.
Eric Platz
10-09-2007 10:34:55
 Re: 44 rear main seal in reply to ChuckBergstrom, 10-09-2007 05:21:55
do you have a manual showing how this is done? is it not possible to just remove the clutch housing? Can I have a phone number to get the seal? What does a major overhaul kit cost?
