MF 135 Aux Hydrolics Valve and plate?
RLA -GA
11-09-2000 08:05:25
I have been told a valve/plate to use the tractor hydrolic system to run a loader is available. I am having a hard time locating this item. One dealer says he can order one for $650.00 and I feel this is out of line. Does anyone know of a reasonable source?
David Coonan
11-14-2000 18:27:27
 Re: MF 135 Aux Hydrolics Valve and plate? in reply to RLA -GA, 11-09-2000 08:05:25
Hi, Such a valve is common in Australia. BARE Co supply a unit that switches between either of two remote outlets and the 3PL. On the remote outlets it is common to fit single, dual or multiple control vales. As the other replies have noted the difficulties are: it either remote hydraulics or 3pl at a flick of a lever but not both together. Second issue is in older 135's not much flow is available (around 4 GPM if I recall correctly) Regards Dave C
lee (MN)
11-11-2000 06:36:14
I have one of these on my 135 and it is a joke, invest the money in a front pump setup. The valve i have came from a tisco dealer 6 years ago for around 350.00. the problem I have is you only get hyd. or 3-point no combination of the two, this is a pain when snoblowing and i want to change the spout direction. hope this helps out.
Tyler(WA)
11-09-2000 08:19:11
Why would you want to do that when you could buy a front mounted pump that would work better and at less cost?
