MF 200 Crawler Torgue Converter
dcsteuer
10-03-2007 02:19:52
I have a MF 200 crawler with what sounds like may be a torgue converter oil level problem (based on Marlowe suggestion from previous posting), but I don't know how to check the oil level. Any hints???
DCS
marlowe
10-03-2007 18:03:54
 Re: MF 200 Crawler Torque Converter in reply to dcsteuer, 10-03-2007 02:19:52
on the side of the bell housing right or left can't remember there is a little inspection hole [has a little cover over it] in side is the TC rotate it till you see some plugs one is steel one is plastic [that's the over heat plug DON'T remove that one] remove the steel one [[[[[DON'T]]]] drop it inside the bell housing. with plug out fill to hole with dextron 2. you can turn the TC with a screw driver one tooth at a time
dcsteuer
10-04-2007 01:48:00
 Re: MF 200 Crawler Torque Converter in reply to marlowe, 10-03-2007 18:03:54
Thanks a bunch. I'll give it a try this weekend.
DCS
