MF 203 Industrial
K.W.
10-01-2007 07:17:08
The problem is I got a CAV Injector Pump on my 1961 model/MF203 and its leaking diesel just about everywhere on the pump. Im wondering could a pump shop even still get parts for a CAV? Or could I get a Bosch Pump to put in place? I heard Bosch is better, but Id need to know if I can use the same injectors and if they make a pump for the A3-152 3 cylinder. Any help would be appreciated!
JerryCPP(WA)
10-02-2007 19:40:59
 Re: MF 203 Industrial in reply to K.W., 10-01-2007 07:17:08
Back when your tractor was new, I was working at an MF dealership. We shipped all our injectors and injector pumps to Spokane Diesel in Spokane Washington. They gave great service and great price, and still do last I heard.
K.W. Tx
10-02-2007 21:14:31
 Re: MF 203 Industrial in reply to JerryCPP(WA), 10-02-2007 19:40:59
Thanks Jerry. I'll look into it. K.W. in Texas
ChuckBergstrom
10-02-2007 04:54:59
You shouldn't need to remove the pump to replace
these gaskets. The replacement is not addressed
in the service manual. There is a seperate CAV
manual which I couldn't get my hands on. I would
see your MF dealer for these gaskets unless you
have a diesel service close by. I'm not an expert
at replacing-just remember selling the parts and
knowing it was done in our shop. Good luck to you.
K.W. Tx
10-02-2007 10:37:26
 Re: MF 203 Industrial in reply to ChuckBergstrom, 10-02-2007 04:54:59
Thanks Chuck. God Bless
ChuckBergstrom
10-01-2007 17:29:52
K.W., 3 of the gaskets on the CAV can be purchased
over the counter and you shouldn't have a problem
replacing them. The top cover gasket,a side
oblong cover and one underneath plus washers on
the bleed plugs. We used to replace them in the
shop and also customers bought and put on. Chuck
K.W.
10-01-2007 21:04:59
 Re: MF 203 Industrial in reply to ChuckBergstrom, 10-01-2007 17:29:52
Should I go to MF parts house or a pump shop to order the gaskets? Mostly Im worried about keeping the pump on timing when I remove it. Would marking the gear to the pump body keep it on time? Any tips? Thanks for replying Chuck
