Need a Part
Gerry Eggart
09-30-2007 17:06:13
Looking for a Tach for a massey MF 203 1961
I believe that the part number is 193956M91 But am only sure about rhe 956M91 part since my manual is a photo copy and I cannot make out the first 3 number.
Anyone have any suggestions?
Thanks
-Gerry
Briar Creek Stables
10-01-2007 19:20:06
 Re: Need a Part in reply to Gerry Eggart, 09-30-2007 17:06:13
Part Number Description Price Substitute Item Order Here 193956M91 Order the New Substitute Part Below $0.00 22776X Order the New Substitute Part Below 22776X WASHER $3.48 Qty: 12345
Here's the link
K.W.
09-30-2007 21:06:29
I got a 1961 203 industrial. I dont know if the number is on the tac. but Im fixin to pull the dash off tomorrow anyways I'll look or ask my parts man. I was also wondering if you have ever had power steering problems with that tractor?
K.W. Tx
10-02-2007 14:35:16
 Re: Need a Part in reply to K.W., 09-30-2007 21:06:29
I see you got the part#. I was a little late! And about the power steering cylinders, you know you can only service the rod end on the original ones and they charge $44.00 for a rubber seal and a two piece plastic washer for each cylinder! Total $88.00 Outrageous!
Gerry Eggart
10-02-2007 10:02:50
Any luck finding the number or with your parts man?
Thanks
-Gerry
Gerry Eggart
10-01-2007 07:45:34
Nope.... other then the cylinders needing seals and me having to remember to add fluid to the pump for the stuff that has leaked out. From the look of the pump... it was rebuilt/replaced not to many years ago.
Thanks!
