Steering wheel tranny
Pap Paw's Tract
11-06-2000 21:27:58
I have a 35 Deluxe that is stuck in first gear. I can shift from Hi to Low range but that's it. I figured I need to get into the tranny but I have to remove the steering wheel and it won't budge. I started with a puller but I'm afraid the steering wheel will crumble. Any suggestions?
Chip
11-07-2000 06:34:55
 Re: Steering wheel tranny in reply to Pap Paw's Tractor, 11-06-2000 21:27:58
Open the oil fill plug on the transmission, stick a large screwdriver in and pop the shifter back, this happens occasionally as the parts wear. You should not have to pull the steering wheel. Good luck
Dan
11-07-2000 05:28:21
Try lots of wd-40 May try installing the nut ,
or one the same size about half way ,then tap it
with a hammer, pulling up on the wheel at the same time.
Pap Paw's Tractor
11-08-2000 05:56:17
 Re: Re: Steering wheel tranny in reply to Dan, 11-07-2000 05:28:21
Thanks for the advice. I had made the mistake of taking the bolts out of the steering column and loosening the steering gear - didn't think hammering would be good. However, I was able to finally put that back together - boy there sure are alot of those thin metal gaskets in there. Since I got it together I didn't have to pull the steering wheel to open the tranny cover. After some careful persuasion and a well placed bungee strap I was able to get my shift rails moving again. Thanks again.
