TO-30 Throttle control linkage
Hal Hadaller
09-26-2007 20:42:57
Where is the friction plate? All I have is a lever by the steering wheel, short link to the throttle rod under the panel connecting to a rod going forward to the governor assembly. What am I missing? Photos would help. Fords have throttle plate by which to set the position of the throttle lever and don't see any such thing for the TO-30
Jeff-oh
09-27-2007 07:51:45
 Re: TO-30 Throttle control linkage in reply to Hal Hadaller, 09-26-2007 20:42:57
The friction plate should be on the verticle part of the hand throttle under the dash.
Hal Hadaller
09-27-2007 09:50:04
 Re: TO-30 Throttle control linkage in reply to Jeff-oh, 09-27-2007 07:51:45
Does one have to remove the casting to see it? Seems that the throttlelever rod goes thru the steering wheel casting and there could be something inside. Otherwise there is nothing other than the throttle lever rod connected to a short link and then to the throttle-govenor rod. Seems that this would be a lot of trouble to remove the steering wheel, etc., to get to the friction plate. My throttle lever is not loose nor does it move hard.
Hal
Jerry/MT
09-27-2007 16:56:18
 Re: TO-30 Throttle control linkage in reply to Hal Hadaller, 09-27-2007 09:50:04
The friction disc goes behind that round plate with the short link and the vertical firewall. It's adjusted with the spring that pushes against the other side of the vertical firewall and a nut attached to the rod, as I recall.
