MF 135 - Wrong Tach ?
Steve IA
09-26-2007 09:58:37
My MF 135 Orchard came with no tach cable. I finally got around to getting one. When I installed it the tach did not run. I checked the new cable and found that when it was attached to the tractor, the gauge end of the cable turned CCW as does the engine as judged by the fan rotation. The Tach gauge must be turned CW in order to register. It doesn't look like a new tach but obviously this one doesn't belong with this tractor
third party image
Printed on the dial face:
STEWART WARNER 823398 MADE IN USA
Printed on the outside case of the gauge:
551ABA8**
525865 M1 The last looking like a MF part #.
Can anybody help me with this? Thanks
Steve
ChuckBergstrom
09-26-2007 15:22:08
 Re: MF 135 - Wrong Tach ? in reply to Steve IA, 09-26-2007 09:58:37
Steve, The p/n 525 865M1 is out of a 1500-1505-
1800-1805 series. This from my microfiche cards
from MF identifying p/n's. Where did someone get
that!!! Chuck
Steve IA
09-26-2007 16:01:00
 Re: MF 135 - Wrong Tach ? in reply to ChuckBergstrom, 09-26-2007 15:22:08
Don't know! But I'd swap somebody for a ccw tach.
Thanks
Steve
supergrumpy
09-26-2007 12:36:53
my 135 (Perkins) tach needle rotates right to left, got used to it and only notice it when my BIL drives the tractor and says something
Finn Md
09-27-2007 13:43:39
 Re: MF 135 - Wrong Tach ? in reply to supergrumpy, 09-26-2007 12:36:53
yeah... I have a MF 135 and MF 165 and the tachs needles rotate in opposite directions. After a long day it still fools me sometimes when I switch tractors and I jump when I see the tach needle setting - thinking holy christ the RPMs are high!
Gerald J.
09-26-2007 10:45:12
525 865 M1 matches no part numbers in my MF-135 parts book.
The Perkins tach comes off the back end off the camshaft and because there's an idler gear between the crankshaft and the camshaft the camshaft turns the same direction as the crankshaft. The Continental gas engine drives the tachometer from a gear box on the back of the generator so the tach shaft turns the opposite direction of the crankshaft.
The two part numbers MF-135 used with the Perkins gas engine were: 528 403 M91 used after 9A146750 (incandescent lamp for illumination) and 194 615 M1 for earlier (electroluminescent illumination) which says buy the later tachometer and a light bulb kit (836 975 M91) for repairs.
Gerald J.
Steve IA
09-26-2007 10:29:19
 Re: MF 135 - w/ perkins gas engine in reply to Steve IA, 09-26-2007 09:58:37
forgot to mention above.
