Massey Ferg. 65 LP No Go?
JKS1
09-25-2007 12:22:42
I was using my LP massey the other day to pull a hay rake....it was pretty hot out and I was working it pretty hard....all of a sudden it just died and won't start...if it sits a while it will fire a time or two then just crank over....is there something that can suddenly go wrong with the LP system and not let propane through....(tank is 70% full)
335LP
09-26-2007 13:38:21
 Re: Massey Ferg. 65 LP No Go? in reply to JKS1, 09-25-2007 12:22:42
Check the ignition system first. Does it have to the plugs after it quits? Coils and condensers can go out when heated up quitting and then no fire when hot and warm but then will fire some again till warm and loses contact inside again. On fuel system a collapsed hose or bad diaphram or faulty fuel guage empty tank you though was full? Most likely wiring or ignition check that first.
