MF 65 antifreeze
Jeff Ziegler
09-25-2007 08:53:45
What type to use? Just ordered a new 180 degree thermostat. I plan on drainging/flushing the hole system. Any ideas how will take to old coolant? The local oil change, where I take my used oil, will not. WalMart will not.
Finn Md
09-25-2007 13:40:51
 Re: MF 65 antifreeze in reply to Jeff Ziegler, 09-25-2007 08:53:45
you should check with local county gov't waste agency, as many counties have haz-mat drop-off locations for homeowners.
get a premium brand pure antifreeze (not a pre-mixed), and make sure you add 50-50 or 60-40 antifreeze to distilled water. Don't use tap water or spring water as such a mixture will create major corrosion later.
