MH 20 top speed
mike phelan
09-24-2007 00:31:39
What is the top road gear speed on MH 20? Is the MH 20 like the 101 JR's that some have a high speed road gear and some have a lower speed road gear? thank you for resonses MIKE ,
Ian Johnsen
09-29-2007 20:02:45
 Re: MH 20 top speed in reply to mike phelan, 09-24-2007 00:31:39
This subject was touched on in a previous forum in regards to a model 81 (same tractor).He had claims of 25-26 mph pulling a hay trailer with like 4 people on it. I am inclined to believe him because my model 20, when stock with two burnt valves, was paced at 31 mph with my buddies pickup. I was told that they could have been ordered with a tall 4th gear.
ChuckBergstrom
09-24-2007 20:13:47
A 22 tractor should be the same. In 4th gear and
at 1800 RPM the speed should be 16.0 MPH. Off hand
I don't believe the 20 had the twin power that you
are referring to. The 101 and several models had
the feature that would allow you to run at higher
RPM if you were not going thru the gears,only the
belt pulley. Chuck
