Pony Stalling
JAA59
09-22-2007 18:22:34
I have a Massey pony that I have rebuilt. New rings, valve job, bearings, carb kit, points, cap, rotor, plugs, and wires. I am trying to get it started. It starts and runs great at idle, up to about 1/8 throttle. Then it dies. Choking does not seem to help. It acts as though it is starving for fuel. I have checked the float, and it seems very fussy. If I try to give it more fuel it runs out the bottom. The jet that goes diagonally up from the bottom doesn"t have a o-ring on it. Maybe that isn"t seating/sealing. Any thoughts? Thanks
51Pony
09-24-2007 14:45:45
 Re: Pony Stalling in reply to JAA59, 09-22-2007 18:22:34
there are some Pony owners out here.
the only thing I've experienced is that the openings inside the fuel bowl get clogged up. mine would run a little like yours and stall under any kind of load. I took everything apart and up under the glass bowl and screen are 4 small ports, they were clogged up.
JAA59
09-24-2007 09:33:19
no pony owners out there?
