MF 30E Powershuttle problem
Dave Ouellette
09-22-2007 14:16:51
My MF 30E has been having a problem engaging forward and reverse lately. Now, it is motionless. I did ck voltages for pedal switches to Vickers valve(shuttle valve). All OK. Coils draw 2 amps,when energized. I will remove and ck spool valve to make sure it is moving smoothly. Are there any external tests/cks that can be made to diagnose problem? Thanks for any help.
Dave O. Florida
Rich NY
09-22-2007 15:35:20
 Re: MF 30E Powershuttle problem in reply to Dave Ouellette, 09-22-2007 14:16:51
What year do you have? Do you have the manual? I have a 1985 MF 30E Loader/Backhoe.Under Fault Diagnosis, mine says "NO DRIVE" - Low oil level or Pump output low- 1.Pressure test pump 2.Pump drive lugs maybe broken off torque converter/pump.
