MF 245 Hyd/Trans Fluid Type/Capacity
Frank, Tx
09-21-2007 12:51:47
I assume the hydraulic system and transmission/rear axle are the same cavity. Would HyTran or equivalent be the correct fluid and what amount? Thanks in advance for the help. (I know - buy a manual). Frank, Tx
135 Fan
09-21-2007 19:06:57
 Re: MF 245 Hyd/Trans Fluid Type/Capacity in reply to Frank, Tx, 09-21-2007 12:51:47
MF perma-tran III works the best and isn't much more expensive. You could use a oil that meets these specs but I've found the MF oil seems to work better. I think it would hold about 8 gallons but not positive. Big Dean or someone else would know for sure. Dave
