weight lift capacity of MF32 industrial
paulatclf
09-18-2007 11:35:08
I hope this is an easy question to answer--what is the weight capacity of an MF32 with a front end loader. Assume everything is in good shape, and rear counterweights are installed. Also--I'd like to put forks on the front instead of the bucket, can I subtract the weight of the bucket and add it to total lift capacity?
135 Fan
09-18-2007 22:25:28
 Re: weight lift capacity of MF32 industrial in reply to paulatclf, 09-18-2007 11:35:08
MF32 is only the loader model. It has a 2500 lb. lift capacity and a 4000 lb. breakout force. The 32 loader was used on the MF20 and MF40 I believe. The MF34 loader was also available on the MF40. Dave
paulatclf
09-19-2007 13:19:11
 Re: weight lift capacity of MF32 industrial in reply to 135 Fan, 09-18-2007 22:25:28
I have the loader, mounted on an MF30? (Diesel) tractor. I want to take pallets off the back of a 53' trailer, and then transport them into my barn. The pallets weigh 1600lbs, and I won't need to lift them for stacking one on top of the other.
Do you think this will work?
Will I need some counter weights>?
Thanks!
Steve IA
09-19-2007 03:50:07
Fan,
Whats "breakout Force"? Thanks
Steve
