MF 360 Hydraulic Pump Strainer Location
jonathan27
09-17-2007 19:03:10
Recent Owner of used 87 360. Waiting for service manual to arrive, but am doing routine maintenance meanwhile. I need access to stainless mesh strainer but unsure as to location or access panel. There is a Power steering pump filter in front of radiator,
thread on type. Any help locating the strainer would be appreciated. Thanks for a fine forum-
jonathan27
09-23-2007 14:36:41
 Re: MF 360 Hydraulic Pump Strainer Location in reply to jonathan27, 09-17-2007 19:03:10
Thank you. Chuck for the clear instructions. I was quoted 35.00 per 2.5 gallons of Permatran. Is this price about right for the trans/hydro oil in other places in US. For 12 gallons suitable for the 360 it runs up to 200 dollars w/ tax for one fill. Regards,
ChuckBergstrom
09-18-2007 08:07:17
Jonathan, There is a linkage pump oil strainer on
the underside of the drive hsg. It is triangular
in shape and help on by 3 cap screws and washers.
You must drain the oil. There is another strainer
on the side(which?)There is a housing held on by
4 bolts and has a clamped hose on the end of the
housing. If you don't find, I'll try to scan but
that may be tommorrow. Good luck
