Well, you could realize that this is likely a losing situation and in the interest of cutting your losses, you decided to pass the deal on to one Aaron Ford who reluctantly accepted. Just Kidding! Congrats on your 65. You are right, the brake has likely stuck. Most need brakes anyway, so this is more of an inconvenience than anything else. Brakes are relatively cheap, too. This is likely not something you would want to fix in the field. Call a wrecker, have him drag it up on a flatbed and haul it home where you can pull the axle trumpet on your own time. It is a big job that will require a engine hoist which you where about to go buy off the Cummins Tool Show anyway right? Along with that heavier engine stand. BTW, if you do not have a serviceable 1 1/16th inch socket and wrench, go buy them now. You can make a beautiful tractor out of any old field eyesore with enough time and effort.
This is the same tractor 21 months apart.
Aaron
