air cleaner hose
oliver88jag
09-10-2007 17:27:08
Does anyone know of a source for the hose that goes from the air cleaner pipe to carb on a Pacer. The hose is about 4" long and has a I.D. of 1 1/4" and quickly increases to I.D. of 1 1/2" Any help is appreciated.
Mark Watkins Ky.
09-18-2007 09:53:13
 Re: air cleaner hose in reply to oliver88jag, 09-10-2007 17:27:08
Im not familiar with your model but I ran in to a similar problem recently. You should be able to go to a muffler shop and have a piece made up. Then use a rubber hose and hose clamps on the ends. Good Luck.
spitz
09-12-2007 10:23:39
I am looking for the exact same piece. I was going to take some conduit and stretch or flare one end and then connect to air cleaner and carb with short hoses like factory. Wont get a chance until after harvest though. Let me know if you find something.
ACEd
09-12-2007 09:05:02
I have not had much luck other than going to local auto parts store and fishing thru radiator hoses for something close - - may have to put a spring in it to keep from collapsing.
