MASSEY HARRIS 33 POWER STEERING
sheldon
09-05-2007 10:19:53
Good day,
Just wondering if anyone is familiar with a way to convert my Massey Harris 33 to power steering?
Any help would be appreciated.
marlowe
09-05-2007 18:57:08
 Re: MASSEY HARRIS 33 POWER STEERING in reply to sheldon, 09-05-2007 10:19:53
i know PS is nice but that 33 should not steer that hard. more then likely your steering gear box is dry and the bearings in the front are shot and dry that tractor is 50 plus years old grease,oil and bearings will do wanders
Sheldon
09-05-2007 21:20:27
 Re: MASSEY HARRIS 33 POWER STEERING in reply to marlowe, 09-05-2007 18:57:08
I will check that thanks...this tractor also has a massey harris loader on it..any kind of load in the bucket sure binds the steering...what is the recommended oil for the gearbox?
Thanks
Sheldon
marlowe
09-06-2007 03:44:58
 Re: MASSEY HARRIS 33 POWER STEERING in reply to Sheldon, 09-05-2007 21:20:27
have you greased the lower breaing ? if not that is the problem it will be shot
marlowe
09-06-2007 04:01:43
 Re: MASSEY HARRIS 33 POWER STEERING in reply to marlowe, 09-06-2007 03:44:58
if you don't fix the front end and put PS on it you will just bust the hel- out of the front end. just drop the front end out and rebuild it
massey333
09-05-2007 17:54:52
You can still get Char-Lynn units,you willhave to make your brackets to mount it but it was and is the best replacement unit.It pays to have a separate pump,just works better(go to a junk yard and get one from a car).
Sheldon
09-05-2007 18:41:33
 Re: MASSEY HARRIS 33 POWER STEERING in reply to massey333, 09-05-2007 17:54:52
Char-Lynn units??? I"m new to the old tractor thing...this is my first
