MF 200 Loader hydraulic pump seal
tennessee mark
09-04-2007 13:04:45
Can anyone tell me the part number of the auxillary hydraulic pump used on the MF 200 loader? Mine is a 3/4" shaft and the front seal is bad with no part number. So far I"ve been unable to find a seal to replace it. My tractor is a MF 203 undustrial and the manual doesn"t have the loader.
ChuckBergstrom
09-04-2007 19:24:53
 Re: MF 200 Loader hydraulic pump seal in reply to tennessee mark, 09-04-2007 13:04:45
Mark, If the pump is original the p/n of the seal
is 833230m1,the front retaining plate-1753531m1,
or the 15 piece seal kit-830740m91. If not avail
from MF, your dealer(any dealer) can order from
"The Parts Depot" in Chilton,Wi. 1-800-743-3768.
The Depot buys stocks of excess or obsolete parts
from dealers and the companies and resells to
those who need. Chuck
Downeaster
09-04-2007 14:14:26
I've got the same unit on my 205 workbull. If it is the front seal it is a NAPA item. Oil Seal # 7513. The seal popped out of the pump housing and I thought that the seal was defective and replaced it. NO FIX, the new one popped also. Took the pump apart, broken internal parts, bearing surfaces worn out in the front plate. The front plate is not available any place. Will replace the pump with another I found on eBay and try to reuse the filter assembly. Wish you luck!
