Questions on MF #25 Disk
scott#2
09-03-2007 19:39:25
I'm looking at buying a 7', 3 point, #25 tandam Massey disk. I'm wondering what type bearings they have and if parts are still available. Also wondering about the weight and any other issues they might have, if any. It looks a little weak at the top link but it's still in one piece. Also, what might be a fair price in good condition, all blades are there and like new, bearings/flanges look tight and in place. It's exactly like the one pictured in the photo forum.
Can anyone make any suggestions on other disks of this size out there that are as good as or better than this Massey? I sure like those adjustment handles.
Thank You,
scott#2
MF Poor
09-04-2007 03:31:03
 Re: Questions on MF #25 Disk in reply to scott#2, 09-03-2007 19:39:25
The #25 uses grey iron "boxings" instead of roller bearings. I was able to get a couple castings through AGCO/MF just recently. They can still be used with a fair amount of wear. The #25 was in production for nearly 40 years. MANY sold. Massey Ferguson is good about parts support, especially on what was a hot selling item.
The #25 is just about as good of a disc as a 3-point disc can be. They do an excellent job of leveling, along with the fact that they dig like a much heavier disc. I"m not sure of their weight, but it seems to be a fairly substancial chunk of iron. I"m very pleased with mine. There was a weight box available for these disc"s when new. It would be very easy to fab a new one. #25 owners manuals appear on ebay all the time. They show a good view of that weight box. Never needed it with mine though.
The gang adjusting levers are nice. There is also a bolt you can remove that allows each gang to "float" independent of the frame.
One thing to keep in mind with a #25, just as with ANY 3-point disc, DON"T try to turn with the disc in the dirt. You"ll twist the frame, possibly breaking it.
In good usable condition, a #25 will sell in the $300 to $500 price range with an occasional bargain below that price, as well as the occasional HIGHER price. I paid $450 for a VERY nice 7"-10" model, then cut it down to 6"-8". (Removed one blade and one spool per gang)
suptscottyb
09-04-2007 15:38:34
 Re: Questions on MF #25 Disk in reply to MF Poor, 09-04-2007 03:31:03
My experience with 3 pt disc setups was disapointing in hard dirt. An old farmer sold me a towner drag behind type(about 8'x7')with steel lift wheels.
It chuns circles around the 3 pt, it turns more dirt and requires fewer passes for tough mustard weed abatement. The lift wheels allow for depth adjustment and tight corner manuvers. The wheels were originally adjusted by a hand operated turnbuckel. With alittle modification they work slick with 10' hydralic lines and a cylinder. I've seen more than one of these old Towners around for 2-300 dollars in good shape. pic avail.
MF Poor
09-04-2007 16:00:55
 Re: Questions on MF #25 Disk in reply to suptscottyb, 09-04-2007 15:38:34
I've got an IH 8'-6" wheel disc. It has it's place, so does the 3-point #25. The advantage a mounted disc has is maneuverability. Also, ease of transportation. (on a trailer)
suptscottyb
09-04-2007 16:30:40
 Re: Questions on MF #25 Disk in reply to MF Poor, 09-04-2007 16:00:55
yep. I give ya that. But if I only had one and I didn't need to move it around, I'ld take the wheel disc. I see a neighbor with a 3 pt here in this hard dirt and it doesn't get in the ground. Just thought I'ld pass it along.
