Carburator adjustment for Massey Harris 44
Pat Walsh
10-30-2000 18:31:08
Was wondering if any one could give me some easy to follow instructions to fine tune my carburator. I put a kit in and does not seem to have the throttle response I think it should have. Any help would be appreciated. Also seems to idle to high.
bob
12-11-2000 08:28:11
 Re: carburator adjustment for Massey Harris 44 in reply to Pat Walsh, 10-30-2000 18:31:08
you have screw on throtle rod on carb you screw it out to slow rpm unless gov is holding to set my 44 for pulling heavy load i open screw and open throthle if it smokes black i go with it setting it down when doing yard work after overhaul of carb i open adjust one and onequarter turn for start
