Massey Harris 16 (Pacer) Snow Plow Attachment
dvdlbt
09-02-2007 07:38:34
I have a 1955 Pacer that came with a Snow Plow. It is missing some Mounting Hardware. 1. The push plate brackets, (although it appears that the drawbar brackets might be used remounted onto the front bolts of the axle houseing.) 2.The lift arms to lifting Mechanism (Triangular Pivot)has me a little perplexed. If anyone has a Photo of this hook up or a good description it would be of great help. Better yet if anyone has any of these brackets they are willing to sell. Dimensions of the stock would help so I can fabricate something,
anything would be of help and greatly appreciated. Thanks dvdlbt
John65
09-15-2007 09:48:17
 Re: Massey Harris 16 (Pacer) Snow Plow Attachment in reply to dvdlbt, 09-02-2007 07:38:34
There are 2 pictures there one for the hyd. hookup and the rear frame hookup.
John65
09-09-2007 15:57:47
Hi There are pictures in the implement photo section here on the side. I have both a pony and pacer they hookup the same.I put a bunch of pictures there.
John
dvdlbt
09-09-2007 17:15:32
 Re: Massey Harris 16 (Pacer) Snow Plow Attachment in reply to John65, 09-09-2007 15:57:47
I found one picture,(Pony Snow Plow Hookup)this was a big help! I had already tryed to fabricate something and I didn't think of sloting the push arm. The plow didn,t have any float.It was either lifted, or down Pressure. I also had the brackets that bolt to the lift arms reversed, End for End! I was able to use the brackets that the draw bar mounts to the axle switched from the back holes to the front for rear push plate brackets but from your picture it appears as though this may be to high! Did you have any other photos if so what where their names? Thanks For the Info! Hope I can help you out sometime!
