Adding hydraulic oil MF 32 loader
Steve IA
08-30-2007 11:54:09
Can't locate a manual yet so will bother you with a question. How does one check the fluid level on this loader, and where is it topped off? There is a likely looking air vent on top of the loader levers. Is this a fill port? Thanks.
Steve
Big Dean
08-30-2007 15:24:48
 Re: Adding hydraulic oil MF 32 loader in reply to Steve IA, 08-30-2007 11:54:09
Steve you unscrew the breather you have to unscrew the piece that is on the bottom that is screwed into the loader frame. If it has not fell off there is a dipstick hanging off of a chain connected to the breather. If the dipstick is missing close all the cylinder the oil should be about 12" from the top of the loader frame. I do have a picture that shows where the breather is located if you need it
