TIMING THE CRANKSHAFT TO THE CAM GEAR ON A MH HIT AND MISS
Tim Thurmer
08-27-2007 20:12:21
We are trying to get our 1.5 hp Massey-Harris Hit, and Miss gasoline engine in working order.
There is no timing mark on the crankshaft gear that turns the cam gear. There is an �o� between two teeth on the camgear. There is the word �spark� stamped on the face of the mag side flywheel. If �spark� on the flywheel is lined up at 9:00 or in line with the valve rod then when should the zero mark on the cam gear be??
Is the timing mark on the fly wheel gear lined up with the key way in the crank shaft?
Thanks for the help!
El Toro
08-31-2007 06:02:08
 Re: TIMING THE CRANKSHAFT TO THE CAM GEAR ON A MH HIT AND MI in reply to Tim Thurmer, 08-27-2007 20:12:21
Put this request over on the stationary engine forum. Some of those that post on there will probably know how to time it. Hal
